- solved - see post # 8
i am testing some excel vlookup scenarios for someone, but i seemed to have found a flaw. it has a limitation of only one column searches.
THE DATA:
THE results of the VLOOKUP output:Code:id A B C D ----------------------------------- 02 123A 123A2B 123A2C CYLI2 03 123B 123A3B 123A3C CYLI3 04 123C 123A4B 123A4C CYLI4 05 123D 123A5B 123A5C CYLI5 06 123E 123A6B 123A6C CYLI6
the above vlookup will search by the id column, and all matching data will fill in columns A..DCode:id A B C D ----------------------------------- 02 123A 123A2B 123A2C CYLI2 03 123B 123A3B 123A3C CYLI3 04 123C 123A4B 123A4C CYLI4 05 123D 123A5B 123A5C CYLI5 06 123E 123A6B 123A6C CYLI6
however, we need to search by other column criterias using any of the other columns, A..D, thus, if i change the vlookup search column 'id' to be column A's data as the new search criteria, so that it looks like this:
the result fails.Code:id A B C D ----------------------------------- 123A 123B 123C 123D 123E
is this a limitation of ms office 2000, 2003, or 2010 ? i only tested this on 2000 and 2003.
is there any other way to set up a search function that i may not know about ?
i messed around with the code some more, trying to figure it out, but to no avail. please note, that the actual original data file is tens of thousands of lines (rows) (or, 60k lines) and about 40 or more columns--all data. but the code snipet above is a very simplified version so that it is easy to follow, i hope. anyway.
the formula i use in the first column A2, is: =VLOOKUP(B2,data.xls!B3:I17,2,FALSE)
then, i fill-right via Ctrl+R, from column B..D to bring up the matching data from column id.
please note, i am using office 2000 here on my desktop pc, but my work pc has office 2003 and 2010. i mainly use 2003 for everything, especially ms access. the data comes from an access query, exported to excel 2003. -
some more details....
we crossreference a lot of files against the main data file. sometimes we need to search by another columns data as the main data to search. thus, we may search by id if we want to know how many elements we have from one clients file against our main data file. or, in other case, we may receive a clients file that we need to search by another criteria to see if any of their data is already in our main data file first, so we will search by any number of their column data. thus, columns A..D may be searched. so we will arrange the search column from the clients file to be in the first column of the vlookup. so it may be whatever column we want to search thoroughly for to make sure we don't duplicate data in our main data file. -
I'm guessing you want to split your VLOOKUP() code (aka formula) into component elements of MATCH() & INDEX(). That way, the first section does the job of finding the right row(s) from the particular column in question and gives the position in the array. Then the second uses that position to give you the filtered row with all its columns intact. IOW, nest the formulas.
Scott -
..nest the formulas.
edit 1: ok, i got the MATCH figured out. so i know how to find the position or row in the column of a search.Last edited by vhelp; 14th Dec 2013 at 09:40.
- solved -
finally figured it out, the custom lookup search, and it works. so, for what i was trying to do, vlookup was not the right method.
....thank you for the tips, after trial and error, it helped me figure out what i needed to do, and i don't have to let the person go!
Excel basic question
By alintatoc in forum ComputerReplies: 2Last Post: 8th Dec 2011, 08:46 -
Help with an IF/THEN formula in EXCEL
By Rudyard in forum ComputerReplies: 4Last Post: 13th Sep 2011, 01:53 -
Excel 07 vs Excel 03
By jyeh74 in forum ComputerReplies: 4Last Post: 1st Sep 2011, 18:22 -
Excel help!
By alintatoc in forum ComputerReplies: 11Last Post: 6th Dec 2009, 20:42 -
How to activate macro's in Excel 2007 with a spreadsheet from Excel 97
By blinky88 in forum ComputerReplies: 3Last Post: 11th Feb 2009, 11:21
